Old 10-22-2017, 10:32 PM
tmx43 tmx43 is offline
Default assembly lube
whats the preferred assembly lube on k motor when being rebuilt. my machine shop recommended gibbs lube that's used on car motors. i thought a motor oil was good. any thoughts?
Old 10-22-2017, 10:55 PM
Oil ONLY. Weight is up to you. I use regular 30wt, or even gear lube. DO NOT. I repeat DO NOT use engine assembly lube. A splash lube engine cannot force the lithium out. It actually will keep oil from lubricating the rod. Just use oil.
Old 10-22-2017, 11:09 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yeah this is coming from a guy who can't even replace the timing chain on his K 301
1- 1200 in pieces
1- 1864 in pieces
Old 10-22-2017, 11:15 PM
No, no no..... it's a driveshaft on a Simplicity, remember?
Old 10-22-2017, 11:21 PM
What he said. ^^^^^^^^^
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-23-2017, 09:12 AM
ok thanks ill use oil then.
