Old 10-25-2017, 08:01 PM
ginsenger ginsenger is offline
Default 60 inch haben deck spindle asy.
Can the center spindle be bought as an assembly or does one have to buy each part separate? For a 2284, 60 inch Haben deck. Looking at replacing double center pulley and complete asy. Take one off and bolt the new one on.
Old 10-25-2017, 08:14 PM
john hall's Avatar
Don't know, look it up on Cub Cadet and see if it is still available as a unit. If not, IHCCW gets in stuff like that every so often. I have heard a few items for the Habans are getting harder to find. Whats wrong with yours? Should be re-buildable.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-25-2017, 09:59 PM
gdheck's Avatar
gdheck gdheck is offline
They are very easy to rebuild. What's wrong with the old one?
Considering just the shaft is in the $150 neighborhood, I don't want to know what they would get for the whole assembly.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 10-25-2017, 10:14 PM
It is throwing sparks and slipping, but I haven't taken it off to see what all is damaged. The pulley is worn and all the rest of them are too. I have been considering replacing all the deck drive pulleys. At 150 for the shaft I guess I should rebuild it.
Old 10-25-2017, 10:55 PM
Stop right there!!!
Before even making a post, you should at the very least look at the machine to see what is wrong with it. For all you know, the belt is loose because it is worn, and something is rubbing a pulley throwing sparks. May not even have any bad parts..... except maybe a broken spring and a worn belt.
Old 10-25-2017, 11:56 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Like others have said... see what is wrong... you may only need a few bearings or a spring.. The bearings are super cheap and super easy to replace in those spindles.. shafts and pulleys do bring big prices.. Patton Acres usually has some Haban parts and complete spindles if you need anything
Jay
Proud owner of the following:
Old 10-26-2017, 09:24 AM
Sounds like the upper pulley has come loose from the spindle.
That's what the issue was with my Haban a year ago.
IIRC, there were only 3 spot welds holding it to the blade spindle.
Simple fix, just re-weld it, that is if it's not so far gone as to waller out the hole in the spindle rendering it junk!
Ya better have a close look before it's too late to do anything BUT replace it!
Old 10-26-2017, 05:55 PM
Its going to need both pulleys, shaft, key, bearings, haven't gotten the assembly off but housing looks ok at this point. With all respect, I know enough to know at a quick glance, more than some would with it tore down. I'm a rebuild man by trade, not yer normal. I'm tired and hurt. It would be the best job to just set the whole thing brand new on it and my 2284 cub would be super and just maybe that part would hold up till i die and somebody else could fix it again.
Old 10-26-2017, 06:08 PM
Does anyone sell an aftermarket assembly or does one have to buy it 1 part at a time and rebuild it. That is my original question?
Old 10-26-2017, 07:43 PM
jaynjeep's Avatar
I have never seen any aftermarket parts for the Haban 60" deck other than blades and wheels.. I don't think they ever offered a spindle as an assy either but I may be wrong on that.. The stuff that is still available thru Cub Cadet is usually very pricey.. I would suggest you hunt what you need used either on epay or through some of the sponsors at the top of the page.. Patton Acres had several items that I needed for my Haban several years ago
Jay
