Old 10-29-2017, 06:55 AM
cdlong's Avatar
cdlong cdlong is offline
Default Can I adapt a #2 tiller to a CCC 582?
I purchased a 1984 CCC 582 w/ creeper to mount a #2 tiller on. As I didn't do my homework before hand, I have an aluminum rear. Is there an adapter or some way to "fit" the #2 tiller to my 582? Also, do I need anything special in a rear lift for this tractor?
Model Number
144582100
Serial Number
2050598U724757
I spent a lot of time getting her adjusted and running correctly & don't want to sell/ trade if I can get the #2 tiller to work.
Thanks for any help.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 10-29-2017, 09:27 AM
CD, here is what I found from a 1988 Attachment Catalog. I am guessing this is a long shot as far as finding these Adapter Packages.
There is always custom fabricating too.
Old 10-29-2017, 01:06 PM
cdlong's Avatar
Smile
Thank you RTTR, (Roland to the Rescue) again.
Papaw
Old 10-29-2017, 01:26 PM
There are only 2 ways that you can put a 2B tiller on a 582 with an aluminum rear.
1.) The way Cub Cadet offered: Use a Cat 0 3pt hitch and a special adapter that is rare as hens teeth to find.
----OR-----
2.) Build your own adapter and make the tiller work with a sleeve hitch.
I did #2.
http://www.onlycubcadets.net/forum/s...ad.php?t=23922
I have since moved my "adapter" to my 1050 and use it. Same set up as your 582.
You will need either a sleeve hitch, or cat 0 3pt to attach the tiller. If your tractor has neither, then you will have to get one or the other. Oh.... and you are going to want a spring assist too. That tiller is a heavy SOB, lol.
Old 10-29-2017, 06:05 PM
cdlong's Avatar
Now I know why folks with the CCC 582's "Just want it gone".
Papaw
Old 10-29-2017, 10:43 PM
Mcamp Mcamp is offline
why not put a cast rear in your 582?
Old 10-29-2017, 11:34 PM
SS5150's Avatar
SS5150 SS5150 is offline
I'd love to have that 582.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 10-30-2017, 08:31 PM
cdlong's Avatar
I will sell or trade, but I need to put that info in the classifieds. Roughly she has 60 hours per year.
Papaw
