Old 11-04-2017, 01:34 PM
Default QA42A clean up and conversion.
I'm getting ready to mount this on the 782, the pulley has been ordered so while I wait I figured I'd get the spout cleaned up. I cleaned the rust and paint off with a fiber wheel and then hit it with some 220 sand paper, then I ran the small buffer on it to shine it up a bit and then gave it a good coat of wax. It's super slick now so hopefully it won't want to clog up all the time.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-04-2017, 03:27 PM
Cool. It will make a difference.
Coat it with oil when you put it away for the season every year. Just like a plow. You might get a little surface rust, but it will shine right up!
Old 11-05-2017, 12:04 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Hopefully you get the chance to use it. We have gotten screwed out of snow the last two years.
1- 1200 in pieces
1- 1864 in pieces
Old 11-05-2017, 12:25 AM
I hear you. Last year i only plowed my driveway twice and i never put the chains on, the ground never froze so it was a muddy mess and the Carlisle's had plenty of traction.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-05-2017, 12:30 AM
Can anybody give me the measurement's for the bent upper arm's?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-05-2017, 01:36 AM
mortten mortten is offline
I have the bent ones on mine. I'll measure in the morning. A new set can be had for $28 plus shipping.
http://ccspecialties.org/implementparts_1.html
Extreme also has them for $32 plus.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 11-05-2017, 11:14 AM
Tim- PM sent
Doug
QA-36A
42" blade
