Old 11-05-2017, 12:47 PM
mfeldmann mfeldmann is offline
Default Belt length 1650 50c deck
Have a 1650 with a 50c deck what is the correct belt length from the engine to the center pulley? Check two different places both places recommended the belt that say 84 in which is too long it's about 2 or 3 inches too long does anyone know the correct length? Thanks in advance.
Old 11-05-2017, 01:23 PM
The 50C mower deck was NEVER intended for the Quietline series tractors. The 44/50C series mower decks were designed for the 82 series tractors.
The correct deck for the Quietline series tractors would have been the 44/50A decks.
Given that, the correct belt for a 1650 with a 50A deck would be....IH-490489-R2 Belt
You can convert a 50C to a 50A by changing the double center pulley to....IH-59703-C2 Pulley
Old 11-05-2017, 01:43 PM
Make it simple, buy a 81,82,83" belts from napa, the one that fits is a keeper.
Old 11-05-2017, 01:47 PM
Default 1650 50cc belt
I've already changed the center pulley to a half inch I just need the belt length. The two places I checked on the Belt gave me a 50A belt but it's too long it measures 84 inches. Need a shorter belt any ideas?
Old 11-05-2017, 01:51 PM
See my post above.
Old 11-05-2017, 02:04 PM
Better get shorter ones than that. Book calls for a shorter one yet.
Roland, the part number for the belt you list does not match my book. I show it takes an IH-117465-C1.
Old 11-05-2017, 02:15 PM
What Cub Cadet said....
IH-490489-R2 Belt, Mule Drive | -44A Mowers w/59 703 C2 Center Pulley on Tractors w/Serial No. 400,000 and below- -44A Mower w/Serial No. 81741 and below on Cadet 1100 Tractors- -50A Mowers on Cadet 1100 Tractor
IH-59971-C1 Belt, Mule Drive | -44A Mowers w/59 703 C2 Center Pulley on Tractors w/Serial No. 400,001 to 529,999- 44A Mowers w/Serial No. 81742 and above all Tractors w/Serial No. 530,000 and above-except Cadet 1100 Tractors- -50A Mowers on Tractors w/Serial No. 400,001 to 529,999
IH-117465-C1 Belt, Mule Drive | -44A Mowers w/Serial No. 81741 and below on Tractors w/Serial No. 530,000 and above-except Cadet 1100 Tractors- 44A Mowers w/Serial No. 81742 and above on Cadet 1100 Tractors- -50A Mowers on Tractors w/Serial No. 530,00 and above-except Cadet 1100 Tractor
Old 11-05-2017, 02:19 PM
I agree.
And a 1650 will have a SN# larger than 530,000.
Old 11-05-2017, 02:33 PM
I agree.
I have one here, used but not abused....
Old 11-05-2017, 02:42 PM
My bad.....looked at the wrong column in CPE-2 catalog.
CORRECTION.......!!!
Belt: IH-117465-C1
Pulley: IH-126393-C1
