Didn’t know that quietlines idled at almost twice what a wide frame does.
Cooling? Charging? This is from an IH service manual:
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I believe it was vibration. Higher idle smooths it out. No balance gears.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Makes sense. I didn’t think of that.
Well I stayed in a Holiday Inn Express last night so....
FWIW, I NEVER set the low idle to what the book says to. I don't want to listen to a low idle of even 1000 RPM. Just too stinkin' fast. I'm smart enough to figure out how to lift the throttle a bit to get the deck engaged if I need to. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I agree with you guys, my 1650 idles real slow
![]() That said, if I snap the throttle open @ idle, the first and second firing impulse with the 18* timing advance, is awful noisy in the block. kinda makes you grit your teeth, so I ease the throttle up. Guess that is why they recommend a faster idle speed. |
You George, you are right. The 16HP is a different animal altogether. It does have to idle a little faster if you want it to come to life with a quick flip of the throttle. But still..... it doesn't need to run at 1800. That's half throttle!
