Old 11-11-2017, 04:39 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
Default 1282 Plow Install Help
Hi guys,
I recently bought a wide frame plow thinking I could install it onto my Cub Cadet 1282. I am having some difficulty. The 1282 also has a manual lift which does get in the way when trying to mount the plow sub frame. I can bend the slotted ends on the sub frame a little bit and it helps but I don't want to push it too far. I'd prefer not to make permanent modifications to the plow or the tractor. Has anyone had similar issues?
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 11-11-2017, 05:48 PM
Take a pic of the plow and post it here so we can see it. Whereabouts in PA are you located?
Old 11-11-2017, 08:17 PM
Dstein16's Avatar
Attached is the picture of the plow. If I made a couple bends in the sub frame, I think it will work. I am in Erie, PA.
-Derek
Old 11-11-2017, 08:19 PM
That subframe is for a narrow frame tractor. Won't work on your 1282.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-11-2017, 08:57 PM
The blade is the same but like Tim said you will need a wide frame subframe and also the plow bracket for the lift rod.
Old 11-11-2017, 09:00 PM
It looks like a piece was added to make it wider.
Here's a NF front blade with dimensions
Old 11-12-2017, 09:12 AM
I'm located just south of you Derek if you need one.
Tags
1282, plow
