Old 11-17-2017, 04:49 PM
Gary C Gary C is offline
Default 782 gas leak
Installed the new petcock and grommet in the cleaned out gas tank, put the snowblower on it, got the little blower filled up and running. Need to put the dozer blade on the 1440 and the chains on both. Went out to the garage today, got gas leaking on the 782 again. This time it's not the tank or petcock or new filter,It's wet around the (I believe fuel pump). So that's the next project to check out. So the gas is shutoff and the "Kitty litter" is doing its job, tomorrows is the fuel pump. I wished I would have looked at it when the weather was warmer, but other projects took priority. (Could use a bigger garage)
Old 11-18-2017, 07:53 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
MMmmm bigger garage, definately!
I just noticed my 2185 is leaking out of the filter, I guess that's what makes these older machines more fun to own, the tinkering that is.
JD x475
Old 11-18-2017, 12:57 PM
I never really"putzed" with small engines before, never too old to learn something. I'm liking it so far.
