Hello, I need some help, I need to replace the drive shaft on my 108 and I've been looking on e-bay and I see one that will fit a 73, a 107, or a 127 and while I think they are all narrow frame tractors I didn't know if there was a difference in the length between the engine and rearend on wide frame or narrow frame tractors, If this won't work could someone tell me what ones will fit, I need to remove the creeper drive is why I need the longer shaft. Thanks, zekepiks
Check this out. It's all you need to know about driveshafts.
If you have a drill press, you can make a new driveshaft yourself. They are just a piece of 5/8" cold-rolled steel. I'd be a bit wary of buying used driveshafts...they wear out. You'll need one from an 86, 108, or 128.
If you make your own, be a bit careful with the measurements in the link Carolina Cubber posted...they are not quite accurate. |
Before i had a mill to make my own, i bought drive shafts from Brian Miller
with no problems with fit whatsoever. |
To be more specific, the roll pin holes for the two pressure plates were probably 40-50 thou too close in my opinion...when I built the clutch for my 582 with those numbers, I had difficulty assembling it because of this. It isn't a problem if you have the pressure plates turned because they will be thinner, but I installed a set that I hadn't turned and had some trouble. The next driveshaft I made, I added some to the distance between those two holes, and it worked fine.
Yeah, if it were mine I would make my own or get one from Brian Miller, and if you don't have access to a lathe send him your plates and have him true them up. For about $30.00 plus shipping, you can have all the work done that you need. Changing the disk is your option, I think a kit is about $50.00.
If you buy a used one on epay, it's still just an old used clutch and shaft and you're most likely going to have to do or have all this work done anyway. |
I just wanted to thank all of the forum members who took the time to reply to my questions,I'm a lead worker on a bridge crew for the state of michigan and we have just started our bridge repair season so some times when I post a question it may be a few days before I get back to view it or to reply, but again Thanks
