Old 11-27-2017, 10:12 PM
tlcan tlcan is offline
Default towing
What is the correct way to tow a cub with a hydrostatic trans? Other tractor I've owned had a toe valve.
Old 11-27-2017, 10:14 PM
Depends on what model it is, what model is it?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-27-2017, 10:18 PM
Never seen a toe valve.......
Default towing
Sorry, I should have included model. It's a 1983 782 Yellow & White
Old 11-27-2017, 10:23 PM
Default towing
I had a couple of old simplicitys that had tow valves and I had an old ford with one.
Old 11-27-2017, 10:33 PM
The 782 has auto valves that automatically release once the engine is shut off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-28-2017, 08:53 PM
sawdustdad's Avatar
Even with auto release valves, you should not tow (or toe) a Cub hydro more than a few hundred feet at very low (like walking) speed.
I've been the recipient of a hydro that had been towed at higher speed. The result ain't pretty:
Old 11-29-2017, 08:05 PM
lift the rear wheels off the ground and use a dolly, etc
