Old 12-22-2017, 02:17 PM
Walker1940 Walker1940 is offline
Default Engine backfires on shutdown
I have a Cub Cadet zrt 42inch deck mower. bought in 2010. Runs fine except when it is shut down the engine backfires one time. Engine is a Kohler SV470-SV620. Tried shutting down at different engine speeds, no change. Carbon Buildup in engine?
Old 12-22-2017, 03:07 PM
Shut down solenoid my be bad. One thing that you may try is to pull the choke as you turn the key off.
Old 12-22-2017, 05:15 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Once you park, try letting it idle for a whole minute before shutting it off. Letting my 1864 cool off helped it.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-23-2017, 08:55 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Slow engine down and shut off at half throttle is the correct procedure according to the Kohler book
Oz
Old 02-04-2018, 05:32 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I'm with Shrewcub on this! Bring down to idle and cool off a minute before shutdown.
Plow blade
#2 Cart
QA36 snowthower
Old 02-15-2018, 09:35 PM
Ozcub's Avatar
I am with the manual Billy O , me thinks they might have a rough idea how to turn off the engine
Oz
Old 02-15-2018, 09:40 PM
Simple,
try both, go with what works
Old 02-15-2018, 09:51 PM
Simple,
What if neither work?
Old 02-15-2018, 10:02 PM
DieselDoctor's Avatar
If niether works, you've got a great way to scare the neighbor when he least expects it!
Old 02-27-2018, 10:02 PM
Shut off fuel supply and let the carb burn out any remaining fuel. My 2008 zero turn did the same, but I had a flame thrower on startup. I could feel the heat on my left arm and the flame was at least 4 feet out with the plastic fuel tan right above it.....Oh, what a ride! It had a hole in the carb bowl and the entire carb needed a rebuild. So, how does the carb hole get a hole in it, damned if I know, but I suspect sloppy work and a wild screwdriver from the shop when I took it in last. My questions to the owner were like a train with no wheels, ......soon get nowhere!
Sounds like you need a carb rebuild...
