Hello
I need to take me steering sector out of my 782D and do whatever is needed. Would like to know the best way to go about it. Thanks |
Drop it out the bottom
http://www.onlycubcadets.net/forum/s...ead.php?t=4631
http://www.onlycubcadets.net/forum/s...ad.php?t=13226 These should get you there. |
Thanks guys
Call one of the sponser's and find one with the three turn lock to lock.
What Joe said.
Can you take the steering box off without taking the whole column out
Can I take the steering box off without taking the whole steering column off
![]() Quote:
You take it out the bottom..... Remove the mower deck (if it's on). Remove the subframe for the deck (if it's on). Remove the steering wheel. Remove the tie rod. Unbolt the hyd valve and support it. Remove the hyd valve plate. Remove the lower bolts. Jack up the front Drop it out the bottom. |
Down load the service manual
http://www.onlycubcadets.net/forum/s...ad.php?t=25397
