Old 01-12-2018, 11:02 PM
Rodster Rodster is offline
Default Moving a 1864
Every time I need to move my 1864 a foot or two, I think about the warning decal and wonder what the failure mechanism would be. Should the tractor be moved 'more than a few feet' (incorrectly) ?
I've done some research and found everything should be OK moving it for quite a distance if you push SLOWLY.
I also saw the Sundstrand has auto relief valves. I guess that's what allows the tractor to be pushed?
Old 01-13-2018, 01:06 AM
If you move it too fast not running, it can explode the hydro pump. Not pretty.
I've done some research and found everything should be ok moving it for quite a distance if you push SLOWLY.
Quite true.
Yes.
Old 01-16-2018, 09:30 PM
Thanks.
I will make sure to move it SLOWLY.....an exploding pump does not sound like a good thing.
Old 01-16-2018, 10:43 PM
Ol'George, a member on here always has the best saying..... he says, "Treat it like a toddler. Don't move it any faster than they can walk or any farther." Pretty good rule. I've moved them a pretty long way without damage. (Several hundred feet.) Just take it slow.
