Old 01-16-2018, 05:45 AM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Rear Axle Seal Size 782?
Hi,
one Problem is done, the next Question is coming.
Next Time, i want to change the Hy-Tran Fluid and Filter, of my 1984 Cub Cadet 782. Have a Cast Aluminium Rear End.
Because the 782 is more than 30 Years old, i want to change the Axle Seals too.
Whats the corrrect Size of this Rings?
At my Case IH Dealer, i can get Hy-Tran Ultraction, can i take this Fluid? Whats the best Fluid for the Tranny?
Have the WIX 51410 Filter,
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 01-16-2018, 05:57 AM
Georg:
Attached is the Rear Axle image for the 782, with serial number 720,000 and greater. You will need OEM Seal Part No: 721-0187------> 921-0187.
As far as the Hydraulic Fluid, Cub Cadet recommends HyTran but you can use what ever Hydraulic Fluid as you have available and see acceptable.
Old 01-16-2018, 07:39 AM
ironman's Avatar
ironman ironman is offline
Georg, The 921-0187 is 1.5" od X 1.0" id X .25" thick. You can use SKF 9876, Google it or search eBay.
Old 01-16-2018, 08:11 AM
ihc353s's Avatar
Thank you yery much for the fast Help, Seal is ordered,
mfg Georg
Old 01-18-2018, 10:58 AM
ihc353s's Avatar
Got the Seals today!
25.4 x 38.1 x 6.35 Millimeters, Meas!
mfg Georg
Old 01-18-2018, 11:22 AM
It is good to hear that you got them locally.
Old 01-18-2018, 03:38 PM
ihc353s's Avatar
You can get yery much, here in Germany, you only must know where. Have this Seals from german ebay.
Next Week, i have Time and the Weatherman says warm and dry.
I'm waiting for the Snow, the Winter is very lazy this Year. My Snowblade and the Blower are stored in the Garage since last Winter,
mfg Georg
Old 01-19-2018, 08:31 AM
mickb72 mickb72 is offline
mfg Georg
Hi Georg, we are making up for you here. Very cold and 8-10" snow on the ground. Last year was our lazy year. Mike
Old 01-19-2018, 08:40 AM
SGragg SGragg is offline
Inactive Member
Glad you were able to get your seals ordered and delivered.
Our last 3 winters have been very mild. This year, we did experience extreme low temperatures, but very little snow.
Looking forward to warmer weather!
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
