Old 01-16-2018, 08:08 PM
Marko141's Avatar
Marko141 Marko141 is offline
Default Creeper gear
Alright creeper gear, does anyone make them still or do I have to go looking for new used ones?
My father had one in a cub he had but ended up selling it off, what does it take to put one in?
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 01-16-2018, 08:29 PM
What tractor are you installing it in?
Old 01-16-2018, 08:33 PM
Unless you bought another one Marko, you can only put a creeper in a gear drive.
Old 01-17-2018, 12:44 AM
Marko141's Avatar
Yeah I had a few I have been looking at, just wanted to track down a creeper drive first.
That and I wondered if anyone still made one but it looks like they are N/A as far as I can tell. I'll keep you guys informed if/when I choose the cub!
Old 01-17-2018, 12:58 AM
No, no one makes them. Haven't in over 20 years. Check ebay, or put up an ad in the "wanted" section on this site.
You should expect to pay between $125 and $150. No more, hopefully less. Some guys are asking $200 or more now..... don't pay it. I would only give more than $150 if it had been gone through and comes with installation gaskets. But still not $200.
Old 01-17-2018, 12:59 AM
Marko141's Avatar
122 will end up being the choice more than likely.
Old 01-17-2018, 01:01 AM
We posted at the same time.... don't miss post #5.
Old 01-17-2018, 01:03 AM
Marko141's Avatar
Thanks for the information
Old 01-17-2018, 12:33 PM
Marko141's Avatar
Found a cub cadet 104 that is solid and runs good with the creeper already in it, guess that solves that issue, only listed for $285, probably offer $200
Old 03-13-2018, 06:06 AM
Be sure and check for sloppy driveshaft issues before purchase.
You may be stuck with an expensive rebuild project such as this 128.
It also needed a throw out bearing, a driveshaft and refurbished clutch hanger w/new pin.
The input shaft repair in this 128 alone is a $50 fix + driveshaft + throw out bearing + PTO + replacement engine and a host of other minor issues (steering rebuild is one) and this $75 "steal of a deal" Cub is pushing $400 at this point.
