Old 03-18-2018, 07:04 PM
IHCubCadet147's Avatar
Default Deck Mulching Cover
Did IH ever make a mulching cover for the 44in decks?
Old 03-18-2018, 09:05 PM
No. The CPE-2 parts book does not show a mulching cover for the 38, 44 and 50 (a or c) decks.
Old 03-18-2018, 09:56 PM
Did they have any kind of shield there?
Old 03-18-2018, 11:47 PM
There is a discharge shield that can be bolted on, yes. But believe me, if you don't have one, you don't want it. They cause the deck to clog in wet or heavy (thick) grass. That's why they are usually missing.
Old 03-19-2018, 08:04 AM
mortten mortten is offline
I made a plate to go on a stamped style deck. It works well with Gator blades.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-19-2018, 04:01 PM
Ok. Do you have a picture or part number I could look up. I would like to at least try something and see if it works for me.
Could you post a picture of it?
Old 03-19-2018, 04:59 PM
I never took the plate I made off the deck last fall and the deck is in storage. I'll be getting it out soon and I'll get a picture. The deflector in a IH 1254726-C1 according to the part manual. Here is a picture.
Doug
QA-36A
42" blade
Old 03-19-2018, 05:20 PM
Looks like the part number is changed to 703-0132-0498. Still available from Cub for $45.00.
Doug
QA-36A
42" blade
Old 03-19-2018, 05:33 PM
Thank you!
Old 03-19-2018, 10:48 PM
And it makes winrows. Does not throw the clippings out evenly...
