Old 03-28-2018, 05:00 PM
Marko141's Avatar
Marko141 Marko141 is offline
Default 127 tiller
Decided to take off the snow blower from the 127 and start hooking up the tiller. This will be my first experience with tilling with this cub cadet so bear with me. I have the gear box attacked, hooked all the arms from the tiller to the gear box without an issue. And yes the mule drive. I did find that the metal rod/bolt coming out of my 3 pt was only intended to be used with sleeve hitch that was on the tractor. So I need to find the needed one or make one. Part number is 485-294-R1. If someone knows where to get one let me know, Cub Cadet says it is no longer available.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 03-28-2018, 05:02 PM
User JeffInPA makes them. Link is at the top of the page. "Parts by Jeff"
Old 03-28-2018, 08:01 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Turn the shaft 90 degrees and drill another 3/16 hole so it is vertical ,plows are horizontal just turn put a hole for cotter pin and use
Old 03-28-2018, 10:23 PM
Marko141's Avatar
That's more than likely what I will end up doing, someone actually made this one as well after I looked at. Someone cut the head off a big bolt and drilled the holes. May just go do the same thing.
Old 03-28-2018, 10:28 PM
Marko141's Avatar
Just a photo of how it sits now. Looks sharp, can't wait to use it.
Old 03-29-2018, 04:39 PM
Yep you need a different lift pin. Tillers are fun!
Old 03-31-2018, 02:15 PM
Marko141's Avatar
Finished up making the new lift pin, works as it should now. Hooked up all the belts and noticed that one of the tensioners on the mule drive was missing... decided to make my own instead of buying one and waiting for it to come in. Photos of the new lift pin to come later.
Old 03-31-2018, 02:27 PM
That style of mule drive is supposed to have a spring on that side, not a tension bolt. There was another style that used two tension bolts, but it is made differently.
Old 03-31-2018, 02:33 PM
It's supposed to have a spring on that side, not a tension bolt.
Most of the tractors I see with a tiller on have two bolts, probably trying to make sure the belt doesn't slip.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-31-2018, 02:38 PM
I went back and edited my post.... but I'll just say it again here.
There are two styles of mules that the tiller used. One used two tension bolts, the other used a spring and a tension bolt. The one in this post is made for a spring. You can tell because it has a larger hole, and the smaller one on top of it.
