Old 04-13-2018, 04:09 PM
Default Plowing with aluminum rearend.
What are some opinions of plowing with an aluminum rearend tractor? This will be a sleeve hitch setup, not cat 0.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 04:34 PM
TNTs CC TNTs CC is offline
Which model tractor or rear end are you talking about?
A SGT like a Cub 2182 with the 3cyl Kubota engine has an aluminum rear.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 04-13-2018, 04:38 PM
V30crewcab V30crewcab is offline
install some braces and get it done.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 04-13-2018, 04:39 PM
Merk Merk is offline
And make sure bolts holding the rear end stay tight.
Project Uncle Dick
Cub Cadet 70
Old 04-13-2018, 04:41 PM
He's talking about the early 82 series with the aluminum rears. A 2182 would have a cat 0 hitch that attaches to the frame.
Give it hell Tim. If it brakes, let us know.....with pics of course.
Old 04-13-2018, 04:44 PM
Know of a gent or two that modify a sleeve hitch to work on a aluminum rear.
Project Uncle Dick
Cub Cadet 70
Old 04-13-2018, 04:55 PM
It's a 1050. I have a lower bracket for the lift that bolts on with the 5 lower cover holes. Thinking about throwing the lift on for plow day.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 05:07 PM
Jonathan plows with his 1050.
Old 04-13-2018, 05:11 PM
True but I'm not sure if he's pulling off the rearend or something else.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 05:28 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Xtreme has this bracket....
http://xtrememotorworks.com/Parts%20...Cub-Cadet.html
Queen Of The Quietlines!
