Old 04-15-2018, 11:43 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default CH series Kohler and PTO clutches.
My BIL and I repowered Cub M- series to a CH series Kohler. We had left the CH PTO installed and it is 6" diameter. The old M motor had a 4 1/2" diameter PTO.
With me having 4 Cub's and several 44C and 50C decks. I'd like to change the CH PTO to a 4 1/2" . Will the old PTO bolt on the new CH? Given I get the correct shaft size.
Old 04-16-2018, 11:24 AM
mickb72 mickb72 is offline
Hello. they should fit. there may be threaded holes already there or divit spots that need drilled and tapped. Mike
Old 04-16-2018, 11:26 AM
PTO should swap as long as they both have the same size shaft.
Old 04-16-2018, 09:20 PM
I went ahead and pulled things apart. Every thing changed over easy enough. Only had one mistake. Had 2 spare PTO's and mixed up the spacers. Good thing I read on a post here that some of the PTO's had different spacers. Sure enough I swapped them.
