Old 04-23-2018, 01:12 AM
Bluecub Bluecub is offline
Default 106 wiring help
Took my cub apart for paint, clutch/driveshaft, and a new engine. Lost the key so I had to replace the ignition switch. Got everything wired up per the diagram, went to turn it over and nothing happens. So I put the switch in the on position and used the jumper cable trick on the starter and it turns over fine. Would this be a symptom of a bad starter solenoid? Or even a bad ignition switch out the box?
Old 04-23-2018, 01:52 AM
johncub7172's Avatar
I recently got a new ignition switch from TSC, and it turned out to be faulty. Sounds like a bad ignition switch that won't let power to the solenoid. Test it with your DMM.
Old 04-23-2018, 02:13 AM
The one I got was also from tsc lol. I will towards that tomorrow, thank you !
Old 04-23-2018, 06:57 AM
ironman's Avatar
ironman ironman is offline
Your first six words gives some indication as to where electrical problems could lie. Solenoid needs a good ground, starter needs a good ground, voltage regulator needs a good ground, battery cable needs a good ground. Did you make sure of all that before you start throwing parts at it? In addition, I can't find the correct switch (IH-60736-C2) for sale on TSC.com. All I saw were MTD switches, which ain't gonna start a NF Cub.
Old 04-23-2018, 07:45 AM
Is the clutch pedal safety switch hooked up properly?
Old 04-23-2018, 09:05 AM
Purchase a new key, install the old correct switch and all will be fine.
I would recommend you not stay @ a holiday inn express
Confucius say, man who lose hotel key get no nukey
Old 04-23-2018, 11:32 AM
Ok I put the old switch back in and cleaned up the ground contacts. Using a screwdriver to turn the switch, still got nothing. Is the diagram I used correct? I have no amp gauge and no safety switch
https://www.google.com/search?q=cub+...ebVKFBowmV3wM:
Old 04-23-2018, 01:30 PM
The diagrams are too small for me to see, but if you have no amp or safety switch, and the wires are there for them, I would think they need jumpered for the power to be available to the components.
Old 04-23-2018, 01:42 PM
There was no wires for an amp gage but there was a wire for the safety switch but it was taped up in the harness connected to nothing on both ends. I did not even know the wire was there until I cut open the harness
Old 04-23-2018, 01:57 PM
ok, since you have a wiring diagram you need to follow it checking that you have power to the key switch, then in the start position , if you have power to the sol. to power the starter.
thinking the 106 is a starter/gen?
is the regulator properly grounded? is the starter properly grounded.
I'm suspicious that your paint has possibly insulated a ground somewhere.
Use your head/common sense during the process, it is something simple, just remember you need power as well as grounds.
