Old 04-25-2018, 12:10 AM
wombat457 wombat457 is offline
Default LGTX 1050 Issue
This is my first post here and need help with a problem my LGTX 1050 has. For some reason every time I engage the PTO for the blades to cut the tractor stalls.
I disengage the PTO and restart it without an issue. It drives forwards and in reverse without an issue. The problem only arises when I activate, or try to activate, the PTO.
Any idea why this is happening and what I might be able to do to fix it? Or is this a "take it to a workshop" problem?
Thanks,
wombat457
Old 04-25-2018, 06:44 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I had the same problem once and it was a dirty carb issue
does it die like you shut the key off? that would be a safety switch issue
if it struggles at all to run, I'd look at cleaning the carb
JD x475
Old 04-25-2018, 07:32 AM
Could you possibly have a stick stuck between the blade and the mower housing?
Or one of the deck drive belts is jammed somehow?
