Old 04-26-2018, 05:27 PM
Cambria cub Cambria cub is offline
Default Power angle blade
Does anyone know a good replacement for the hydraulic cylinder # 717-3031 That's not a arm and a leg?
Old 04-27-2018, 09:19 AM
sawdustdad's Avatar
See this thread.
http://www.onlycubcadets.net/forum/s...ad.php?t=51205
I used this cylinder: (recommended by another member here)
https://www.surpluscenter.com/Hydrau...-9-4410-08.axd
Old 04-27-2018, 04:53 PM
Thanks that's the same thing I would like to do to the 1811 same set up. Nice job
Old 03-13-2026, 09:38 PM
Farmall450's Avatar
Originally Posted by sawdustdad View Post
See this thread.
FYI, link is dead, here's a new one. https://surpluscenter.com/1-5x8x-75-da-hyd-cyl/
Specs are 1.5x8x.75 Double Acting Hydraulic Cylinder [900686]
Product Description
1.5" x 8" x 0.75" DOUBLE-ACTING HYDRAULIC CYLINDER
Brand new. Welded cylinder with internal gland retainer. For agricultural and industrial applications. Small sizes are ideal for remote control of valves, spouts, etc.
SPECIFICATIONS
Brand Columbus Hydraulics
Model Number LD-1.500-1646
Double Acting
Bore x Stroke 1.5" x 8"
Pressure 2000 PSI max.
Rod Dia. 0.75"
Column Load Unknown
Ports 3/8" NPT
Retracted Length 13.5"
Shpg. 10 lbs.
END MOUNTINGS
Rod End Cross-Tube
O.D. 1.26"
Width 1.25"
Pin Hole 0.75"
Base End Cross-Tube
O.D. 1.26"
Width 2"
Pin Hole 0.75"
