Old 07-03-2010, 04:10 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
Default 1450 vibrating bolts out of muffler shield
Hey all. My 1450 keeps vibrating the bolts out of the muffler shield. When I check vibration by hand, the engine is so solid that the tractor shakes? It also vibrates the coil wire out of the coil. I changed it with one from my blown 782 and it still does it. What might this be? ISO mounts? Woudn't they move by hand as well?
Thanks.
Old 07-03-2010, 05:44 PM
Do you have lockwashers on the bolts? You might need to squeeze the end of the plug wire a bit to make it fit tighter in the coil. That problem is common to all of the K-series singles, not just the ones in the QL tractors.
