Old 04-29-2018, 08:01 PM
mefarmer mefarmer is offline
Default 129 Hydro adjustment?
New to the forum here, with my 129 Hydrostatic machine.
I'm having a problem with the tractor increasing speed, doesn't matter if I am in forward or reverse.
Say I am cutting grass at a steady speed, if I take my hand off the forward/reverse lever, the lever starts moving on its own and the tractor increases speed.
Is it normal, to have to hold the hydrostatic lever in one place for it to maintain speed?
I've had this 129 for probably 20 years, and it has always done this, I just swapped out to a ported hydro and added the hydraulic lift and was just wondering if this is normal or some linkage somewhere I can adjust?
Thanks
Old 04-29-2018, 08:21 PM
There is a "friction" nut at the end of the Hydro Lever Handle. Needs to be adjusted. Got to the Tech Library Section and download the Service Manual that shows and explains on how to do it.
Old 04-29-2018, 08:31 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
There are two styles for the hydro linkage on the wide frames. Later styles above serial number 503725 use the friction nut. Here is the link for this repair
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
PDF page 78
Queen Of The Quietlines!
Old 04-29-2018, 10:06 PM
Thanks for the link DeltaCub. Was hoping it would be something like this.
Something to work on tomorrow evening!
