Old 05-01-2018, 11:08 PM
brudder brudder is offline
Default Mount wideframe plow on Cyclops
Does a subframe that fits on a Quietline series (wideframe I think) fit on a Cyclops? It looks to me like the Cyclops subframe the arms are bent out to fit on the outside of the frame, but the the one I'm looking at that's mounted on a Quietline looks like it mounts inside the frame rails. Sorry if this is a simple question. General internet searching and searching OCC didn't turn up an answer for me.
Old 05-02-2018, 06:29 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
It works but because some of the Cyclops have a supersteer front axle that raises the front end it changes the geometry of the plow when it's angled causing one corner to be in the air in the other digging into the ground. Otherwise the actual quick patches sand
1- 1200 in pieces
1- 1864 in pieces
