Old 05-02-2018, 06:58 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Default My plow, field cultivator and crumbler this spring
I went to Phil Klines plowday on April 7th earlier this month in Kewanna, Indiana and thought I'd share a quick video link and some pics of that day. My tractor and 2 bottom plow with buster bar worked great with no hiccups. There were 52 tractors there and we plowed between 25-28 acres. I also worked my field that I grow sweetcorn and soybeans in last weekend with my field cultivator and crumbler. That setup works great, worked up moldboard plowed ground from last fall and also planted all my soybeans and my first 8 rows of sweetcorn out of 40 . Yes I know planter is wrong brand and color but I got a great deal on it and replaced every wear part on it last year along with paint. Thanks in advance
https://youtu.be/9-1kuyRYkMI
https://youtu.be/8M91XnNfHvs
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 05-02-2018, 08:23 PM
Awesome videos, thanks for sharing.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-02-2018, 09:14 PM
dirtcowboy's Avatar
Your very welcome, Thank you as well
Old 05-02-2018, 09:24 PM
Really cool. I think I like the mini 5488 the best. The vents in the hood are a super cool touch.
Old 05-02-2018, 09:28 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Maaan, that is a sharp setup. Seems like you add more every year. You do a good job mocking down the big stuff into useable micro machinery
1- 1200 in pieces
1- 1864 in pieces
Old 05-02-2018, 09:32 PM
dirtcowboy's Avatar
Thank you
Old 05-02-2018, 09:36 PM
yettrbomb yettrbomb is offline
That’s bitchin! Looks and works great!
Old 05-02-2018, 09:37 PM
dirtcowboy's Avatar
Thank you, I appreciate the kind words. I'm guilty when it comes to adding more and more implements lol, I get ideas and then start building them. I just picked up.a cat 0 field cultivator I'm gonna tear down and paint and put new sweeps on. Next year my buddy can use it in my field on his 1772 while I use the pull type field cultivator and crumbler on mini 5488. I'm still working on plumbing my 28 side dressing applicator for my sweetcorn, hopefully get it finished here soon.
Old 05-02-2018, 10:26 PM
Awesome as always Jerry.
Can never get enough of your equipment at work, or play.
Thanks for the vid.
Old 05-03-2018, 12:49 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
you my friend have some of the nicest tractors and equipment around these parts.. I can see the time. love and care you put into them. Congrats
Jay
Proud owner of the following:
