Old 05-05-2018, 02:04 PM
mattoney mattoney is offline
Default Brinly Disk?
I'm hoping that I can post some pictures on here and people can give me an idea of what exactly I have. A few years ago, I purchased this Brinly Disk and a Grader Blade for $50.
This disk is a bit confusing because it doesn't fit what I've found on the Brinly literature. It appears to be similar to a rear gang Brinly DD-500. I see no evidence where the frame has been cut or welded though. It may not even be a Brinly, but someone put a Brinly sticker on it once.
So I was just hoping someone could see this and help identify what I have. Thank you for your time!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 05-05-2018, 02:30 PM
It is a Brinly, but is isn't a DD-500. It's a lot newer than that. Don't know the model number of it.
Old 05-11-2018, 07:06 PM
Rainman Rainman is offline
Default Brinly disk
You need a hammer strap to bolt the hitch so you can hook up to a sleeve hitch.
Old 05-11-2018, 07:15 PM
Default Brinly disk
Old 05-12-2018, 09:02 AM
And a lot of weight to really make it DO ANYTHING.
Tags
brinly, disk
