Old 05-08-2018, 03:50 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default IH 48" deck
Hey all, I've been trying to do my due diligence but it seems good old google is fighting against me or else I'm searching the wrong things. Anyway the IH 48" deck under my 125 just upchucked the spindle belt. I can only find information on the newer model deck(aside from user manual). Does the newer deck belt fit the older IH deck? If not does anyone know the part number for this belt? I would like to get this mower running before the weekend so my kid can keep slinging grass. Any help would be greatly appreciated...Thanks Earl
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 05-08-2018, 04:59 PM
MiniXP MiniXP is offline
I'm seeing part #IH-489399-R1 on the cub cadet parts website for a 125 with a 48" deck.
You may want to go double check yourself since I don't know the exact years of your equipment.
The Service and Parts section of cubcadet.com has your tractor and lists a 48" deck under attachments.
Old 05-08-2018, 06:43 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I would go with a IH481099-R2 per this pdf chart which is hosted here:
www.cubcadet.info/Manuels/Belt-blade_&_PTO_ref_guide_1947-2004.pdf
page B5
Being the 125 was not built after Aug. 1969
I do not know why but the IH-489399-R1 is for a 48" narrow frame tractor and it has the loop style skis instead of gage wheels.
Built after the CC125 ended production.
The earlier narrow frame 48" deck does not have the skis and has gage wheels that are on brackets welded onto the deck outboard of the tractor tires. and uses belt IH-481099-R2
