Old 05-09-2018, 11:25 AM
Gary C Gary C is offline
Default K 17 series 11 engine manual 782 cub
Pulled all the covers on the engine and cleaned it all up, figured as long as everything is accessible, I should maybe pulled the heads and clean off the carbon. Access to a manual for torquing the head bolts would be nice, can someone send me the specs and the sequence? I found a vendor to get a new "lift cylinder" from on the site. (Old one shaft broke off piston) I would have tried to drill it out and install a long set screw to repair it, but my lathe is way to small for that job
Old 05-09-2018, 11:31 AM
Did you look here....??? Link..... Kohler KT-17 Service Manual
Old 05-09-2018, 12:15 PM
Thanks Roland! I couldn't find that earlier. (Now to go to the "desktop" to print it). Thanks again. Gary C
