Old 05-10-2018, 10:49 AM
Brownell1991 Brownell1991 is offline
Default No start issue
Hi there I have a cub Cadet original that my father in law recently gave me and I am having issues getting it to start. The motor does turn over fine the starter engages with no issue replaced oil plug and wire and cleaned the fuel bowl and lines. I pulled the plug and grounded it out and found no spark. Any ideas?
Old 05-10-2018, 10:56 AM
Everybody has their own way of doing things so here is what I would do. I would remove the points cover and run a piece of fine grit paper between the contacts and see if that doesn't solve the issue, the points just might have some corrosion on them and need cleaned up. If that doesn't work your going to need a multi meter so you can see if you have 12v going to the positive side of the coil when the key is in the run position. Start there and report back.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-10-2018, 09:35 PM
sawdustdad's Avatar
80% of the time, it's dirty points. That's my first step, too.
Old 05-10-2018, 11:52 PM
Little new to these old mowers. Where is the point cover? And I did check and I have 12v to the positive side of the coil.
Old 05-11-2018, 02:49 AM
If you’re looking at the air cleaner it will be the 7 o’clock position from it on the engine. Small vertical cover with 2 screws. Follow the wire from the negative side of the coil, goes right to it.
Old 05-11-2018, 06:58 AM
Terry C's Avatar
Terry C Terry C is offline
The guys have you on the right track.
Welcome to OCC.
Are you from the same town as Hazel Sig? ( If you are you will get that, otherwise you will think I’m an idiot. So will everybody else!)
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-11-2018, 08:32 AM
Welcome to OCC.
Built a few Sig models in the 50's, so you are not an idiot
Old 05-13-2018, 08:50 AM
smalljob's Avatar
smalljob smalljob is offline
Hopefully you found the points cover but here is a picture for you. The thing with the red button is the points cover.
Old 05-13-2018, 08:56 AM
As if anyone who has no idea what they are looking for will find it. That wasn't really very helpful.
Old 05-14-2018, 10:07 PM
Okay cleaned the point and still no spark but have 12v going in to coil any ideas?
