Old 05-11-2018, 06:47 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Default Kohler KH-235935 Gas Tank
My gas tank on the 125 has sprung a leak. Besides having the leak repaired, I'm looking into possibility of replacing the tank rather than do a repair. I understand the KH-235935 tanks are NLA. I wonder if there are NEW alternatives available reasonably priced?
Thanks, Bill
Plow blade
#2 Cart
QA36 snowthower
Old 05-11-2018, 07:01 PM
How about checking with our sponsors for a good used tank and placing an Ad in the Wanted Ad Section...???
Old 05-11-2018, 07:29 PM
sawdustdad's Avatar
Another option is to go to your local O'Reilly's (or other auto parts store) and buy a can of Red Kote. Use that to line your gas tank. It's a thick solvent based sealant for sealing gas tanks. I did that to a 73's tank over 5 years ago and it's still holding fine. It's made for automobiles, motorcycles, etc. so it should work fine you your tank unless it has a large hole.
Tanks can also be soldered if it's a seam leak...
(purge the gas first!)
Used tanks are readily available, as already noted.
