Old 05-11-2018, 11:18 PM
nophun nophun is offline
Default 1872 what is this hole for?
On the drive shaft cover, above the label, left of center, there is a "D" shaped hole, the kind you'd mount an electrical switch in so it doesn't spin.
There's a dull ring in the paint around it, so something was there, it's a factory punched hole and paint is still intact.
Of all of the thing I will have to do to get this machine mowing again, this is what I'm most worried about; these are the kind of things that keep me up at night.
Old 05-12-2018, 12:02 AM
How about posting a picture of this hole...??
Old 05-12-2018, 12:21 AM
Here it is, you can just make out the ring around it in the pic.
Old 05-12-2018, 01:35 AM
You have an oddity...... but we have seen it before. I had actually forgotten about this. But there was a tunnel cover that was made for a 3rd PTO switch.
Read this:
http://www.onlycubcadets.net/forum/s...ad.php?t=47681
Old 05-12-2018, 08:05 AM
Read this:
Thanks for the link, that clears up what the hole is for. I had noticed the 2 holes for the extra switch and fuse holder on the tower when I first unloaded the tractor.
None of these hole have ever been occupied by a switch; the paint would be marred if the had, I'm going to assume the dull ring around the hole on the tunnel cover is from a blank-out of some sort to keep rain water out.
Old 05-12-2018, 08:08 AM
I would assume the tractor had a rear PTO and someone removed it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-12-2018, 11:04 AM
OR....someone swapped tunnel covers.
Old 05-13-2018, 01:55 AM
Steve N Mi Steve N Mi is offline
I have an 1872 with the extra hole in the tunnel cover.
Looks almost like there was something mounted in the hole when painted, difficult to see but there is no yellow close to the hole. This shows up better in the last picture.
The red circle is around print stating Model 1872, 2072 on the bottom half of the tunnel decal.
File Type: jpg Tunnel Decal for models 1872 and 2072 .jpg (28.0 KB, 109 views)
Old 05-14-2018, 08:18 PM
My label is too far gone to read much of it, I see your tractor has 2 fuse holders which is part of the 3 switch setup if I'm reading right.
What I can't figure out is in what situation one would use front and back PTO at the same time? Of course I don't know what all of the available implements were.
Old 05-14-2018, 09:50 PM
The directional PTO Switch on these SGT's was "one or the other". It was never setup up to run both.
