Old 05-12-2018, 03:44 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Cub cadet 149 hydro filter
Mods, please move this if in the wrong section. I was looking at the CCC and NAPA cross referencing section and and CCC lists part #723-3014 for the filter, NAPA part # 1084. Then there is listed a hydro filter for auto gear pump. Has the same CCC part# but a different NAPA part# 1410. I bought the 1084 filter before I saw this. Can I use the filter I bought or should I buy the 1410 filter? All help appreciated. Have a great day.
Bob
Old 05-12-2018, 04:27 PM
Did you look here...??? Link.... Filters
Old 05-12-2018, 04:35 PM
Terry C's Avatar
Terry C Terry C is offline
I only use 1410s
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-12-2018, 04:38 PM
Dart1917 Dart1917 is offline
1410's don't have an anti-drainback valve (so I've read) to work with the autogear pumps. The 1084 is for the older Sunstrands. Either one will work. 1084 is what Napa lists for your 149.
Old 05-12-2018, 05:23 PM
A 149 has a Sundstrand. The 1084 has caused issues in the past on a Sundstrand. No, the 1410 doesn't have the drain back valve. That's why it works better. Been a long time since I looked at the over priced filter from MTD, but pretty sure it doesn't have a valve either.
Old 05-12-2018, 05:45 PM
Every filter that is listed in the link and has been researched, cut open and examined, and found to be accurate and correct. They meet Cub Cadet and Sundstrand specifications and Standards.
Old 05-12-2018, 06:04 PM
I use Wheel Horse ones, got them cheap and they are the same as a cub one.
Up to 534 and counting...
Old 05-13-2018, 09:14 AM
ironman's Avatar
ironman ironman is offline
I have been using Fram PH2844. No problems, compatible to all on the list and decent price.
http://www.oilfilter-crossreference....rt/Fram/PH2844
http://www.fram.com/parts-search/PH2...5VNl1tjD9VAukA
Old 05-13-2018, 09:36 AM
Per the Fram (PH2844) site.... "Designed for use with conventional oil"
Old 05-13-2018, 10:26 AM
ironman's Avatar
But it shows as a replacement for all on our list of hydro filters?
