I found a place that has the thick rubber strips for snow blades made from old conveyor belts. They will custom drill the holes for you. I bought one so I'll see how it looks when it arrives.
http://rubberwearstrip.com/index.html |
I have seen these or similar on ebay. I'm interested in your results and feedback.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580 |
This whole rubber strip snow blade has been done before. Works fine for soft snow. Hard or driven on snow it won't touch. I'll stick with a steel share. It always cuts.
Yeah, just depends what kind of shape your driveway is in. If it's concrete and broken up and different levels, or gravel, the rubber strip may work better. Especially gravel since a steel blade will scrape the gravel up and leave you with more work in the spring to rake it out of your yard. But to each his own.
I tried a rubber strip once. Made the blade shake worse than a K series Kohler on fresh snow, and rode up and over packed stuff. Best thing I ever did was buy a strong metal cutting edge from xtreme a couple of years ago. Rubber is a total waste of time IMO
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
![]() Quote:
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Then you have absolutely no chance of getting down to the pavement even on the smooth parts.
The part I wondered about is this rubber strip is actually 1" thick. I've never seen them that thick before, so I don't know how "choppy" it will be. Guess we will see. |
The key to the rubber edge is to have a couple of inches of hangover so you get the squeegee effect. You need the flex for a smoother cut. Been running one for a couple of years on a bobcat, works great for me.
I was a cheap skate I cut the tread out of a 4 ply tire and bolted behind the metal cutting edge. So far has worked well for our Ky snows. I also removed skid shoes.It will chatter at times at higher speeds but no problem if slow down. It will also work like a squeegee in slushy snow.
Ed Wells Jeffersontown Ky |
Yeah, this rubber strip might work well down south where snow falls fast and leaves fast.... but even here in south Central Illinois, it would be a joke. Nothing cuts like a metal edge, and a good operator can run the blade on any surface. I used to clear parking lots, driveways and sidewalks with my tractors. Steel cutting edge did a great job and was never an issue, no matter the surface. Plus, I use my blades to push dirt and rock too, so I'm not switching.
Someone said it's personal preference..... not really. More like inexperienced operator who needs it to be easier to compensate for ability. Sorry if that offends.... just how I see it. I learned at the age of 10 on a 340 Farmall (IH) tractor how to blade snow off gravel and keep it from digging in. It can be done. |
