Old 05-16-2018, 12:40 AM
swacor swacor is offline
Default SGT tillers
Wanted some opinions on how the tillers perform? Ive never ran one or seen one in person. I was looking into a rear pto and tiller for the 2284, so i thought i would ask.
Old 05-16-2018, 07:18 AM
dale c. dale c. is offline
rear pto's are hard to find and not cheap , you might be better off finding one with it's own engine , I assume you have the 3pt. hitch already...
Old 05-16-2018, 09:09 AM
Yea i have the 3 point already. I know their hard to find but curious how well it works with the right tiller.
Old 05-16-2018, 09:11 AM
It works just like any PTO driven tiller. Ever ran a tractor with a tiller? Works just like that.
Old 05-16-2018, 10:39 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
They work fine but with a 48'' tiller on the back you need a 100 pounds up front to keep the nose down
Old 05-16-2018, 11:18 AM
Leadslingingdaddy's Avatar
Filling the front tires help also... and they are a beast... Get the weight bracket from Extreme and hang some weights on it....
Old 05-16-2018, 12:20 PM
We have a 6 ft king cutter we use now on the farmall 504. I just thought it would be nice to have something a little more compact for the garden. We also have 540 48 inch john deere but that wont work on the cub due to the hook up plus it will spin to fast, is this correct or could the pto be slowed down with different pullys?
Old 05-16-2018, 12:30 PM
Tillers can be found easy enough.... Search for PTO's on ebay or trashed 982's 1872,
2072, 1914, 1912's... they are out there.... Found a 1914 with 3pt and PTO for 100 bucks at an auction.... heard the comments that "he paid way too much for that".... DA didn't know what the 3pt brought.... Typical Bailing Wire crowd....
Old 05-16-2018, 01:29 PM
Well this is interesting it looks like this had a pto before. For some reason the stud for the tightener was removed and the hole on the plate covered up.
Old 05-17-2018, 12:31 AM
As far as I know, all SGT's came with the cover plate for the PTO. Why someone welded the hole shut for it is beyond understanding.
Before you delve into this, have you priced a PTO set up? The tillers usually bring less.
