Old 05-23-2018, 11:39 PM
GaryC GaryC is offline
Default 125 - Starter Generator
Hello,
Our 125's Delco Remy Starter Generator recently died and I came across a someone selling a reconditioned dixie d in our area, which I thought unusual.
They no longer have the tractor it came from and couldn't tell me the Cub model either. Sounds like it was a quite a while ago that they had the tractor.
I haven't had the time to even price out a kit for the Delco here in Canada (tired of the costly customs brokerage BS), nor the time to get a quote from one of the shops in the city for an overhaul. Waiting on a recommendation on which shop to call, or avoid. Not from the region.
The Starter for sale is a dixie d TG79
And our dead Delco is a 1101951
Could someone verify if that dixie will work on our 125 ?
And I fully expect someone to bring up that I ought to just get the Delco working rebuilt, keeping her original and all, which I plan to, but it's about time at this point.
WAY too much on the go presently and fixing this machine is very low on the totem, but the Cub was just starting some needed work, to avoid hiring work out.
ALSO, recommendations on parts suppliers for our 125 would be greatly appreciated.
Thank-you,
Gary
Old 05-23-2018, 11:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
What is a dixie d? Tried googling to no avail.
Queen Of The Quietlines!
Old 05-23-2018, 11:59 PM
Good question. But not a good way to start off . . .
In the photo he sent me, it's what is printed on the tag, and the code is stamped.
Old 05-24-2018, 01:30 AM
According to this:
http://www.dixie-electric.com/catalo...?Num_Dix=TG-79
That is a generator, not a starter/generator. It will not work. Apparently, Dixie is a reman company. I don't know why the Google machine didn't work for you Beth. It popped up on my first try.
Old 05-24-2018, 05:54 AM
IF.....you are going to use Dixie Electric as your source, the correct Starter-Generator would be their Part Number 301-18102
Old 05-25-2018, 12:02 AM
Thanks Roland for the dixie d part no. for our 125.
And Jonathan for that reminder to always ask Google first. What could go wrong?
Incidentally, that's how I came to an ad for a "Cub Cadet Starter / Generator" on Kijiji.
After a couple days back and forth the seller finally sends an image clear enough to read the tag. In the end, no better clue other than, "the hood was square."
He's an old guy cleaning out the garage.
So there you have it. I'll be sending the Delco to town for some love.
Thank for your efforts.
Old 12-05-2020, 11:59 AM
Can anyone tell me the normal temperature range for a starter generator?
I was plowing a bit last night and afterwards noticed how hot the starter generator was. Too hot to grab for more than a second. I can't remember ever being concerned about its temperature before.
Thanks,
Gary
125
Old 12-05-2020, 01:04 PM
I would venture to say, there is an issue.
Old 12-05-2020, 04:56 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Did you have a lot of load on it? Like charging up a dead battery and running a lot of lights?
Make sure connections are bright and tight!
Plow blade
#2 Cart
QA36 snowthower
Old 12-05-2020, 08:21 PM
Thanks,
Gary
125
My brothers SG was doing this on his 129- fry an egg on it hot within 5 min of mowing (or less). Started smoking. It was putting out 17 volts on a good battery. Check yours running it should be about 13-14 volts. turned out his voltage regulator was bad. It will get warm (the SG) but you should still be able to touch it after running it for a long time.
