Old 05-30-2018, 07:04 AM
wisesettler wisesettler is offline
Default LT1050 died & now won’t run, except on starter fluid
GF has a LT 1050 died while mowing, acted like ran out of gas but had half tank. Has new fuel pump & since i messed up solenoid, had to put new carburetor on which came with new solenoid. Fuel pump is pumping gas, solenoid is retracting when key turned on, & bowl on carb has fuel and still will not run, but will if using starter fluid. I sure hope someone can help me with this mind boggling issue. We have only one place locally that works on lawn equipment & taking it there is out of the question. They have had my John Deere 3mos so that’s that. Thank you
Old 05-30-2018, 07:23 AM
First, welcome to OCC....
but will, if using starter fluid.
You have a Fuel Delivery problem,
Old 05-30-2018, 07:33 AM
I realize that but it puzzles me as to where problem lies. Fuel pump is pumping & fuel is in bowl of carb
Old 05-30-2018, 07:42 AM
cooperino's Avatar
Did you adjust anything on new carb? Was there any junk in the fuel?
Old 05-30-2018, 07:49 AM
Something inside the Carb is plugged up.
Old 05-30-2018, 05:21 PM
No i didn’t adjust anything on new carb. I called where i ordered it from to confirm there shouldn’t be anything to adjust for it to start and run. As for as debris in gas tank, i dint see any but all it takes is one piece. Will pick up new fuel line and check carb for debris in a few hrs. Thanks guys for your input
Old 05-31-2018, 05:33 PM
cooperino's Avatar
Pull the new fuel solenoid and turn on key. see if the plunger retracts.. You may need to ground the outer case of the solenoid. If you bought a cheap after market china carb.. could be the issue
Old 06-01-2018, 12:22 AM
I did and it does retract
Old 06-01-2018, 07:59 AM
cooperino's Avatar
OK. so the valve opens which means Your not pulling fuel to intake. A couple of things can cause this. Did you replace the gasket for carb? If you did, did you clean the surface real good? If your certain there is no vacuum leak then I would say either bad carb "happens frequently with certain after market junk" or there was crap in your fuel that plugged carb immediately after install and could be why it shut down in the first place. I would take the carb back off and remove the bowl and see whats in there.
Old 06-01-2018, 09:15 AM
It would take an ENORMOUS vacuum leak for the engine not to be able to draw fuel into it. Like, HUGE. Like, the bolts that hold the carb on would have to be very loose, or missing. Suggesting a vacuum leak as a reason it won't start is a near impossibility. Especially if you are just suggesting the gasket wasn't replaced or cleaned well.
The chances of this brand new carb being "junk" is nearly as impossible. I have seen a lot of bad parts out of the box, but never a carburetor. I've seen a carb have something plugging it up that likely got in it at the factory. Metal shavings, or cardboardlike material from shipping.... but never one that was just junk and had to be exchanged. Have you, cooperino, actually encountered a new carb out of the box that was bad???
The last suggestion of dirt or junk in the fuel system..... there it is. That has been the suggestion since the beginning! It is the most likely. It is the most common. It is the solution that makes the most sense, both as to what originally happened, and why the new carb didn't fix it.
Let's also not rule out things like, does it have gas in the tank? Gas as in gasoline, and not accidentally diesel fuel or kerosene?? That would also cause this condition. If it was mixed, it would smell like gas...sort of... but not have high enough octane to run. Seen this many, many times.
To the OP:
Drain the fuel tank, flush it and the fuel lines out. Remove the carb bowl and clean it. Put new fresh gas in. Replace the filter. Push the gas through the system. Make sure the carb fills up. Try again. You might even have to take that brand new carb off and take it apart. It may have dirt stuck in the main jet. Buy it likely isn't a bad carb, and I'm sure it isn't a large vacuum leak.
