Old 06-01-2018, 05:57 PM
982cub 982cub is offline
Default Fuel pump opinions
Good Afternoon fellas,
My first post on here as I am racking my brain trying to get my mower running. I took one lap around the yard on my 982 this evening and it died. The fuel pump is not working. I have transplanted a Kubota 3cyl. Diesel in it and from what I can tell it has some sort of Facet cube style pump on it (came with the motor). I found a pump at NAPA part # 610-1050. 4-7 psi at 32 gph. Do you think this will do the job or to big? Wasn't trying to wait for the mailman to get the grass cut, but if I have to I will. Thanks in advance!
Old 06-01-2018, 07:40 PM
Kubota dealer will have the pump cheaper than online.
I got one one my 1512 for like $69.00
Up to 534 and counting...
Old 06-01-2018, 08:03 PM
cooperino's Avatar
Originally Posted by 982cub View Post
Afternoon fellas, first post on here as I am racking my brain trying to get my mower running. Took one lap around the yard on my 982 this evening and it died.. fuel pump is not working. I have transplanted a kubota 3cyl. Diesel in it and from what I can tell it has some sort of facet cube style pump on it( came with the motor). I found a pump at napa part # 610-1050. 4-7 psi at 32 gph. Do you think this will do the job or to big? Wasnt trying to wait for the mailman to get the grass cut, but if I have to I will. Thanks in advance!
The Facet pump will work just fine.. Your using it as a lift pump only. The price is fair at $50-$60 and Facet is one of the best brand pumps..
Old 06-01-2018, 09:56 PM
The Kubota, did it have a mechanical, or electronic pump on it? Could have had either....
If you get an electric pump, make sure it is rated for diesel fuel.
