Old 06-09-2018, 11:33 PM
Walker1940 Walker1940 is offline
Default Engine wouldn't shut off.
I have a 42inch ZRT mower. I removed the engine cover to clean up some grime and used air pressure to clean around the carb. With the cover off, I started the engine. Then used the key switch to shut down. Engine still running. Got off the seat, expecting its safety switch to shut down to engine. Nope. I finally got it shut off using the lever arm sticking up thru the slot that holds the governing mechanism. There is a white wiring socket next to the front deck of the engine that was not seated completely. That fixed the problem. FYI. Any suggestion on how to stop the engine otherwise?
Old 06-10-2018, 12:20 AM
Oh, I don't know.....
You could pull the choke or shut off the gas.
Old 06-10-2018, 12:30 AM
Anybody ever tell you you're a dick?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-10-2018, 12:40 AM
Yeah.... couple times, lol.
To the OP, have someone video you pulling the plug wires off though. I want to see it.
Old 06-10-2018, 09:24 AM
Not quite the response I expected. 🤔
Old 06-10-2018, 10:05 AM
Ok,
lets put it another way.
Shut off the gas, or let it run till the tank goes dry.
Remove the plug wire (S) with an insulated fuse puller.
Pull the choke lever, or remove the air cleaner and stuff a rag in the carb intake.
Remove the carb.
if the exhaust system is tight, plug it up with shovel handle if the right size.
If it were a gear drive, I would suggest putting it in gear and gently let the clutch out @ idle in high gear to stall it.
About all I can think of.
Old 06-10-2018, 11:20 AM
Well I originally said to pull the plug wires off bare handed AS A JOKE but someone apparently thought I was serious.
Old 06-10-2018, 11:44 AM
cooperino's Avatar
I'd make sure my hands were good and wet first.
Old 06-10-2018, 02:05 PM
RLause's Avatar
RLause RLause is offline
I did that once when I was a kid, just to see what would happen. The wire was insulated, what the heck. Found out real quick. I did a lot of dumb stuff that gave me a good education.
Richard
Old 06-10-2018, 02:23 PM
Most everyone who has turned wrenches much has been bitten.... and still remembers it, lol. I know I have... several times. I got bit adjusting a distributor once because either the cap had a crack, or a wire was bad. I still hesitate to grab a distibutor when adjusting timing.
