Old 06-11-2018, 12:53 AM
Wayne Wayne is offline
Default Best deal on 108 generator
Help me out, I need a generator asap and don't know where I should get it. I see some on the bay but they could be Chinese junk for all I know. Whats a reliable, not too terribly spendy source for one?
Cub Cadet 2166
Old 06-11-2018, 05:54 AM
I assume, you are talking about the Starter/Generator on your Cub Cadet.
It is widely held here, that taking the Delco-Remy S/G to a reputable repair shop, is far better than buying the foreign made replacements that is seen on popular auction sites.
If you are determined to replace rather than repair, your luck is as good as anyone elses's here.
Old 06-11-2018, 08:06 AM
Agreed...
It's a crapshoot at best.
Some times you win, sometimes you loose.
I just recently lost...
Found one I had gotten somewhere and forgot that I had.
Dropped it off at the shop 2 weeks ago. I have been using this shop for a couple years now w/great results.
They got around to checking it out and called the other day...
Unit is basically junk, may be able to salvage the end plates but the main parts are toast, oh well!!
Last 2 I took in cost about $60 total IIRC for complete service.
Good luck!
Old 06-11-2018, 09:57 PM
Rebuild it is then.
Cub Cadet 2166
Old 06-15-2018, 01:15 PM
Bad news. The armature is toast. They said its almost 100 for the armature alone, and ~180 to rebuild. And they said the armature would probably come from the same overseas manufacturers of the import s/g's I'd like to avoid. Not an appealling thought.
A member emailed me about rebuilt ones he has so hopefully that will work out.
Cub Cadet 2166
Old 06-15-2018, 02:18 PM
Terry C's Avatar
Terry C Terry C is offline
Did you try the sponsors on top of the page? Should not be that hard to find one
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-15-2018, 08:48 PM
I checked the websites of several sponsors and didn't see one
Cub Cadet 2166
Old 06-16-2018, 04:32 PM
I did get a call back from one of the sponsors who recommended the imported starters at DB Electrical. Said he's sold many and had very good luck with them so that's what I'm gonna go with. Sent PMs and left messages for several members who replied, but I havent heard back from any yet and I need to get this ordered before the grass blocks my view out the window.
Cub Cadet 2166
Old 06-16-2018, 06:39 PM
Bamafan Bamafan is offline
Inactive Member
I put one on my 129 a year ago and so far it works fine. I wouldn't hesitate to order another if needed. Be sure to order a CCW if you order one.
[B]Larry[/B]
Old 06-16-2018, 08:06 PM
Yep, that's what it is.
Now if only I can find a bracket, because mine is badly stripped and probably irrepairable, at least by me.
Cub Cadet 2166
