Old 06-22-2018, 05:15 PM
Pop Pop Pop Pop is offline
Default 3205 axle bearings
Hello everyone. My 3205 started leaking oil from the right axle tube.
I tore it down to diagnose, went to Cub Cadet website to order parts,
They say these parts are no longer available. Does anyone know where these bearings and seals can be found ?
I thought i was sol so i bought a donor 3235 thinking they would have the same rear, wrong, doesn't match.
Any help appreciated, Thanks
Old 06-22-2018, 05:26 PM
Can't you just knock the needle bearing out and replace it? Bearings and seals can be bought from a bearing company, ordered online, or possibly even picked up from an auto part store. Should be part numbers on the bearing and seal, but if not search by size.
Old 06-22-2018, 06:52 PM
Oak is the 3000 series guru, I'm sure he will be along to help you out.
Old 06-22-2018, 09:53 PM
I'm in the process of doing my 3205 with lots of pics.
Here is a 3165 with the same setup as yours without the locking differential.
http://www.onlycubcadets.net/forum/s...ad.php?t=33446
Here is the new number on the seals from Motion. I just had 6 shipped to my door for $32.08.
https://www.motionindustries.com/pro...p?sku=02336089
The needle bearings are HK 3020.
https://www.motionindustries.com/pro...p?sku=03240027
Old 06-22-2018, 10:09 PM
Thank you so much .
What a relief.
Now all I have to do is try and sell the 3235 and recoup my losses
