Finally got my 129 operable. On the lowest deck setting it keeps throwing the belt. Far as I can tell, everything is adjusted properly. Current belt is an OEM 490489 belt. Looks fairly new, but has lots of nicks due to ALOT of problems prior to me owning it.
Going to try a new belt. From what I read, the 490489 is a 80" X 1/2" belt. Then I read elsewhere and it's a 81" X 1/2"? Will a Gates Equipment 80"x1/2" green belt be a suitable replacement? Thanks! Kevin |
Depending on which deck you have, you might need a 3/8" belt.
Forgot to add that, I have a 3 blade 42" deck.
Have seen the above mentioned belt listed as 1/2" AND 3/8" also? Thanks! |
Well took the deck off this morning and noticed some play in the center spindle bearing. Think this is allowing the pulley to tilt and prolly not helping matters. When I serviced the deck, clean and greasing everything along with sharpening the blades everything seemed tight. Guess it didn't last long.
Looks like I need to either replace the center spindle or just the bearing along with the belt now. |
Someone previous to me had the center spindle of my deck apart. Put everything back together with upper and lower housing on top and bottom of deck. Compensated with a bunch of washers. Didn't work real well.
That lowered the center of the pulley (among other things), and just in general caused a mess.
Wore out 129. Projects: 1969? 147, 1971 chevelle SS conv 402/4sp bench, 1965 chevelle wagon, 1973 trans am drag car, 1973 triumph 650 chopper, and oh yeah, working on the house too! |
I dont think you will have very much luck with the Gattes belt lasting very long.
As the deck belts run with twists and bends in it and is design to take the abuse where other belts are not designed to take that kind of abuse. |
The Gates green belts work good for this. I have one that's lasted me several seasons on my various 82 series tractors. They're more expensive than the OEM belts, so there isn't any savings by using one, though.
I think there is a misconception on a lot of parts, especially belts, that OEM costs more than aftermarket. In a few things, that may be true, but I have found that for a good quality belt, that OEM belts are priced fairly competitive against the aftermarket ones, and sometimes cheaper. This is true for Cub Cadet, John Deere, etc. You may find them cheaper, but they're usually inferior than OEM and you're end up paying more in the long run by trying to save a few dollars buying aftermarket.
