Old 07-07-2018, 05:26 PM
durant7 durant7 is offline
Default 1250 PTO Problems
I would appreciate some help. I am working 15 hours away from home and the wife reports the mower deck belt broke. 1250 Hydrostatic with (I assume) electric PTO as I have a PTO switch on dash. She replaced the belt and no joy. Asked her to follow the PTO wire and she reports one black female dangling off frame, one wire, no connector coming out of the PTO. Hmmmmm.
Simple as getting my Son to solder the wires together for now? What was the original routing of the wires? Stress level pretty high at home and I am trying to reduce it somehow. I hate being helpless.
Actually, I was thinking I should just have him jump the bare wire coming from behind the PTO and it is snaps shut, wire re connection and safe routing is the best thing they can do to get the machine back on grass duty.
Thanks in advance!
Jud in Ohio, Cub Cadet in NH. Manual in front of me.
Old 07-07-2018, 06:14 PM
cooperino's Avatar
Thanks in advance!
Kinda hijacked the post here bud... Anywho, Jump the wire? Power needs to be provided to coil. If your saying to jump it somehow to make it stay engaged? Not a good plan at all.. Dangerous for one thing. If the wire can be soldered back on that is the route I would take. Hate to see a live pto and blades spinning take someones toes off..
Old 07-07-2018, 06:29 PM
twoton twoton is offline
From the pto switch there is a wire that runs down along the left side of the tower and along side the engine before it connects to the PTO. It looks like this. Do you have this wire?
Old 07-07-2018, 06:31 PM
There is another wire that comes out of the pto and connects to the previous wire. Do you have that one?
Old 07-07-2018, 08:03 PM
NOTHING to solder.
Simply cut back the insulation on both wires, to bare the copper. Put the two wires together with a "wire nut". It will work until further or better repairs can be made.
Old 07-07-2018, 08:06 PM
cooperino's Avatar
NOTHING to solder.
Yup, That will do it so long as ya have the space and the wire is not cut to short. Good call!
Old 07-08-2018, 06:51 AM
Sorry to hijack the thread. It seemed in the same neighborhood when I searched on PTO.
By jumping...I only meant for them to do this as a diagnostic to see if the clutch was working. There is about 2" of wire coming from behind the PTO. The other end, still has its original connector. I will advise them to reconnect via some method which may be splice and wire nuts or solder.
Thank you for confirming there is just one wire that needs to be connected.
JD in OH
Old 07-08-2018, 07:40 AM
No problem. Good luck to them.
