Greg Rozar AKA- CubDieselFan
Old 07-16-2018, 05:45 PM
Tmccray Tmccray is offline
Default Cub 1100 Carburetor Trouble
First, I want to say hello to everyone and thank you for having me aboard. This is my first post. I finally got my first riding mower and a proud owner of my first Cub Cadet 1100. Paid $250 for it and could not be happier. Runs/ran great. Mowed one lawn and the started my restoration project. Found that the carb needed attention when it started having VERY high RPM's. No adjustment would work so i assumed internal flaw. Found that the governor rod? that attaches to the plate on the inside had a great deal of free play, the seal was warn out of it and the throttle body plate was loose and has an over sized hole for the screw in there. I am attaching pictures. Is there ANY way to repair this, find a new Carb or a repair kit that would include these parts? Everywhere i look there is no kit that comes with the parts i need and this Carb is no longer available.
Any advice?!?!
How do I post a video?
Serial: 2050590U630872
Engine; Model: 253417
Type: 0132-01
Code: 78051911
Carb: BS-392690
Old 07-17-2018, 02:10 AM
169kw 169kw is offline
Default 1100 carb
I believe that I have a carb that was almost new when I removed it from an 1100 that had a junk engine. I will try to look tomorrow.
169, Kwik-Way loader, 1100 (going to transplant a 10 hp Kohler in it)
Old 07-17-2018, 06:48 AM
cooperino's Avatar
Is this your carb?
https://www.ihccw.com/carb.html?product_id=2613
Old 07-17-2018, 07:25 AM
Yeah, That's it, trying not to spend more than i paid for the tractor on the carb...Not if i can fix it.
Old 07-17-2018, 07:29 AM
@169kw That would be great. If it's the right one How much would you take?
Old 07-17-2018, 08:04 AM
cooperino's Avatar
Any advice?!?!
Type: 0132-01
Code: 78051911
Carb: BS-392690
Oh, ok I didn't even look at price. You said it was unavailable.. So if you dont want to do that, You can rebuild and repair the over sized hole or you could possibly find a different part number carb for the 11 horse and adapt to your engine.
Old 07-17-2018, 08:08 AM
cooperino's Avatar
Heres one I found a little cheaper...
https://powermowersales.com/392690-C...R-Snapper-Part
It was for snapper but should be same carb
Old 07-17-2018, 08:12 AM
cooperino's Avatar
One more option.. Found a used one.. Not pretty but you might be able to get the parts you need off it.
https://www.mepcigoods.top/briggs-11...k-p-19468.html
Old 07-17-2018, 09:03 AM
Welcome to NO LONGER AVAILABLE.
If you think you can fix it, get to fixing and quit asking questions.
The 1100 isn't a very desirable tractor. Not many people want them, part of the reason is because of the engine. Not going to be much out there for it.
I think you better be looking at your governor before spending any money on a carb. Governor is usually the cause of high RPM. Even if the carb linkage is shot and the engine tries to run too fast, the governor should be trying to shut it down. If it's not, the governor is likely broken internally.
That says it is NLA.
Old 07-17-2018, 11:46 AM
That's the thing, the governor arm that is attached to the rod that goes through has about 1/4 inch of play before it even moves. I was thinking of just trying to do a tac weld? somethign that would delete that play? and about the over sized hole in the disc which is not tight at all and moves around freely in the carb, maybe just get a comparable washer and make it work?
