Old 08-02-2018, 09:23 PM
thadscub's Avatar
thadscub thadscub is offline
Default rebuilding k301as for 123
hi guys iam am waiting on the crank to come back from being turned i have a choice on 2 blocks one that the conecting rod broke on are a used block that will need a possible bore job done on which way would you go
thanks thad
Old 08-02-2018, 09:45 PM
sawdustdad's Avatar
Best to bore the block regardless. Only way to get a good, true cylinder. Get the oversize piston and rings. Cost to bore block and regrind valve seats should be about $200 at your local NAPA shop. Plus the rod, piston, rings, valves and gasket set at about $110 and you've got a new engine.
Ebay seller bat4kids: https://www.ebay.com/itm/MASTER-REBU...ty!22576!US!-1
Old 08-02-2018, 09:55 PM
You need to bore it either way. Building an engine without boring it is just a hack job that won't last. Sometimes when the connecting rod breaks it takes a chunk out of the bottom of the cylinder and if the chunk is big enough then the block is junk so make sure you check the blocks really good before buying one.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-02-2018, 11:07 PM
Either one will need bored. Doesn't matter.
