Old 07-12-2010, 08:13 PM
57130's Avatar
57130 57130 is offline
Default Correct tire size??
I have an easy question. I'm working on getting Tru powers for my 149 and I was going off the manual for the tire sizes. It said 23x8.50-12. But when I got too looking at the tires on the tractor, it had 23x10.50-12 tires. I also found that the 1450 had the same when they both should be 8.50s. My questiong is, am I missing something and which one is it supposed to be?
Thanks
Old 07-12-2010, 08:37 PM
According to the Spec Sheet, the 149 had standard rear tires of: 23 x 8.50 -12. Optional was the 23 x 10.50 -12.
Old 07-12-2010, 08:51 PM
You mean 6-12 rears? I've never heard of a 23-6.5-12 tire
Old 07-12-2010, 11:14 PM
57130's Avatar
So do I need to get 10.5 tires, or will 8.5 tires work too? Did the dealer use 10.5 rims with 10.5 tires, or were they the same rims?
Old 07-12-2010, 11:18 PM
fisherman1526 fisherman1526 is offline
They are not the same rims, the 10-5's are an upgrade from the dealer. If you have 10-5's, put them back on.
Old 07-13-2010, 01:35 AM
ajgross ajgross is offline
Inactive Member
Measure your rims. 7" wide rims use 8.50's. 8.5" rims use 10.50's. Although you can put 10.50's on 7" rims, they look a little funny.
AJ
Old 07-14-2010, 08:36 PM
Mr.Jeffro Mr.Jeffro is offline
57130,
I have a 1650 with the 23x10.5x12 tires and just ordered a pair of Carlisle Tru-Power 23x10.5x12 for her. I have seen several pictures of other members with the same type of tire and I typically have to wipe the drool from my mouth after viewing.
Just one more thing to upset the neighbors. :biggrin2.gif:
