Old 08-17-2018, 03:21 PM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Default 1641 rebirth
I picked this 1641 recently. After repairing some cracks in the grill mounts, I removed the intake and carb to clean, (to take care of the surging engine), and replaced the leaking front tires. Some fresh paint, and I have a great running 650hr Cyclops.
1450SGT
1641
528 SWE Snowblower,
Old 08-17-2018, 03:37 PM
cooperino's Avatar
Lookin great!
Old 08-17-2018, 07:22 PM
CubDieselFan's Avatar
How did you repair the grill mounts?
Old 08-17-2018, 07:47 PM
Terry C's Avatar
Terry C Terry C is offline
Nice work.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-17-2018, 07:56 PM
mrjeep81's Avatar
I used fiber glass cloth and 2 part epoxy. Things don't stick to the plastic so well, so I drilled randomly placed holes, (you can see a few in the pictures), then applied the epoxy heavy enough to fill holes. I also "allowed" the cloth to touch itself as much as possible through the openings, (oh I felt so dirty typing that!)! By wrapping the cloth "around" the mounting tabs it greatly strengthened the mounts. Also the holes filled with epoxy will help bolster the repaired area. I didn't get after pics, but I'll pull the side covers off when I mow next and get some.
1450SGT
1641
528 SWE Snowblower,
Old 08-17-2018, 08:23 PM
brudder brudder is offline
I used Plastaid to repair some of the Cadet plastic. It was recommended on here by others. It seems like good stuff. I can tell there's a good chemical bond occurring, because it gets really hot while it's curing.
Old 08-17-2018, 10:19 PM
john hall's Avatar
That is one sweet looking machine. If it were mine, I'd spring for a new grill while its still available (hopefully).
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-06-2019, 09:39 PM
mrjeep81's Avatar
I’ve not been on too much of late, but wanted to update a little. I removed and freshened up the 48” deck and put the 1641 in storage. I am one of the GM employees losing my job in Lordstown. I am most likely going to be going up to Tonawanda NY, (Buffalo), and will b staying in an apartment until retirement so no grass cutting. No tractors. No garage. 😞
File Type: jpg EEECDA38-9612-4DEF-AE60-54D0A894DEDB.jpg (25.8 KB, 104 views)
1450SGT
1641
528 SWE Snowblower,
Old 01-07-2019, 10:51 AM
mortten mortten is offline
Sorry to hear.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 01-07-2019, 05:29 PM
jknight jknight is offline
Good luck with your employment.
