Old 08-22-2018, 08:09 AM
Pray-2-miss-rocks Pray-2-miss-rocks is offline
Default M18 engine head milling
Last month, bought a 4.5 acre house/property. I was going to buy a zero turn, but in the barn was the previous owners 1811 that's been at the property since it was new. After using it a bunch, I'm saying F a zero turn, because I love this mower. It's nostalgic, the hydro system makes for an efficient and effortless mow. Plus, has a 50" deck. Had to put an ignition coil on but it's a solid runner now.
Is there a norm for head milling to run on 93? Carb jets to match?
Valve adjustment specs?
Is there an engine code I could search other than m18?
Anything else I should know?
Old 08-22-2018, 08:27 AM
Why run on 93? Just use 87 and it will be fine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-22-2018, 08:56 AM
Leadslingingdaddy's Avatar
You say that now. ��
Old 08-22-2018, 09:01 AM
Ditto.....no point in running 93 Octane.
The 1811 rolled out of the Factory with a Kohler M18-24506 Engine in it.
Old 08-22-2018, 09:03 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Default Welcome
Another 1811, great! What kind of shape is it in? Snap a bunch of pics and post them here for us.
I just got an abandoned 1811 last year and I've been going through it to fix the neglected items. I'm impressed with the quality. I posted a lot of pics of my repairs that might interest you.
I bought a dozer blade and a snow thrower for it too.
I'm near Annapolis MD. How far away are you?
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 08-22-2018, 09:11 AM
Higher octane is for engines with high compression, it basically keeps the fuel from igniting early in high compression engines so there no need for it in a garden tractor engine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-22-2018, 10:20 AM
You don't need 93 octane. Where on earth did you get that idea?
I love Cub Cadet tractors..... but I'd rather mow with a ZTR. Way more efficient. Especially if I had 4.5 acres to cut, which is a ridiculous amount. I'd keep the 1811 for chore work. Get some other attachments for it....but I would get a ZTR. Or maybe in your case a 12' batwing finish mower, lol.
Old 08-22-2018, 11:07 AM
Didn't Sam have a setup for sale??
Old 08-22-2018, 12:40 PM
Who said anything about needing 93 now? Lol. Did anyone read my post or was I not clear (I dunno how I could have been clearer)? I'm wondering if there is a "run of the mill" milling (pun intended) amount that will increase compression to run safely on 93 octane.
Otherwise thank you for the info.
Mower is in good shape, have all kinds off attachments as well. Obviously the old man original owner loved it. I think it's perfect for my yard, half the property is woods, other half grass. It's also a mix of flat, hills, and....rocks. a zero turn wouldn't really save me a lot of time
Old 08-22-2018, 12:54 PM
You can run it on 93 the way it is, no milling required. You don't have to have high compression to run 93.
Why do you feel the need to run 93?
Pap's 100
Restored 108
1211 Dual Stick
1050
