Old 10-01-2018, 09:57 AM
samckitt samckitt is offline
Default 54" 2554 deck on 1872?
Mounts look to be a different but wondering if anyone has done it, can it be done?
________________________
Scot
Old 10-01-2018, 10:01 AM
Ten characters say no.
Up to 530 and counting...
Old 10-01-2018, 10:49 AM
nophun nophun is offline
This is the second time I've seen this recently, what does it mean?
Old 10-01-2018, 10:59 AM
Terry C's Avatar
Terry C Terry C is offline
You can’t just type no as an answer. Answers to posts are 10 character minimum
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-01-2018, 11:04 AM
Sam Mac Sam Mac is online now
If you had a junk 317 or 324 deck you could use the mounts and make it work.
Old 10-01-2018, 09:13 PM
farmall fred's Avatar
farmall fred farmall fred is offline
With some fab work it could be done. I ran a 60 in deck from a 5252 that I adapted on my 1872 for about 15 years and it mowed very well. I used the mounts, hangers, jack shaft pulley assy and a modified mule drive from a GT 46 inch deck to make it work. I later ended up getting the hanger assy from a 60 in Haban because the one for the GT deck was not made of heavy enough material and it kept bending due to the weight of the deck. If you have fab skills and a welder etc it can be done. It would be easier to find a 54 inch deck from a Cyclops series or a Haban as they will just bolt on with the exception of the PTO pulley size used with some of the later Cyclops mowers. Here are some pictures of my 60 in deck I adapted. The only reason I stopped using it is I found a 60 inch Haban deck to use on the tractor I rebuilt that is in my avatar.
Rear mounts and jackshaft pulley Overall view of mounts
side view, Haban hanger assy adapted
Mounted on 1872
