Old 07-15-2010, 05:45 PM
57130's Avatar
57130 57130 is offline
Default New Tires!!!
Well, I'' finally getting new tires for the 149. I have 23x10.50-12 Tru-Powers on order from a dealer here, and they should be in off the truck from Colorado Springs right now!! After I finish telling this I'm gonna go pull the wheels off and throw 'em in the back of the truck to be ready to get 'em tomorrow. I almost fell out on the floor at aprice of 237.10, but I know it's worth it. I was wondering also if you guys always put tubes in your tires when you load them and also haw much weight you can usually get by loading full of RV anitfreeze? Also, is it worth it or should I just use my 42.5 pound weights and call it good.
Thanks!!
Old 07-15-2010, 08:11 PM
aagitch's Avatar
aagitch aagitch is offline
If you're going to use it for plowing or other ground engaging stuff I'd fill them.
Old 07-15-2010, 10:56 PM
ihnick's Avatar
ihnick ihnick is offline
i loaded my trupowers with almost 6 gallons per tire. there a sweet tire with lots of traction
Nick.
Old 07-15-2010, 11:15 PM
fisherman1526 fisherman1526 is offline
I use windshield washer fluid. Got close to 9 gallons per tire in mine.
